Inventor Forum
eps file
6 REPLIES 6
bengee5454
3588 Views, 6 Replies
eps file
Does anybody know how I can open an eps file?
6 REPLIES 6
CAD-One
in reply to: bengee5454
It should be a postscript file, try openning in adobe programs.
http://en.wikipedia.org/wiki/Encapsulated_PostScript
C1
Inventor Professional 2020
Vault Professional 2020
AutoCAD 2020
CCarreiras
Hi!
You can open with adobe Illustrator.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
mcgyvr
in reply to: CCarreiras
yes.. any of the "graphic" programs can open it.
Corel/Photoshop/Illustrator/Image ready
GIMP (sort of a free photoshop alternative)
Hi ben.gee,
In addtion to the other suggestions, I'll add that I use this free EPS file viewer from time to time:
http://epsviewer.org/download.aspx
It's pretty basic, but it works for my needs.
I hope this helps.
Curtis
bengee5454
in reply to: CAD-One
i tried using adobe programs - no luck.
I havent got Adobe Illustartor.
I also downloaded gimp software, no joy.I also found that I have Corel Draw on the computer - my spirits were (momentarily) lifted......until I found that wouldnt work either!
i will try
hopefully I'll get somewhere
Cheers
Ben
