Inventor Forum
End line to Revolutionize Ellipse
9 REPLIES 9
Message 1 of 10
emaiolino
1192 Views, 9 Replies
Good afternoon,
Can anyone help me to keep this line appears to apply Revolution to a stretch of "Ellipse".
Thank you very much!
Esteban Maiolino
Titular EMBA Proyectos
Sitio web o nombre del blog
Facebook | Twitter | LinkedIn
9 REPLIES 9
Message 2 of 10
PaulMunford
in reply to: emaiolino
You will get that with a revolve. It shouldn't matter, but if it's bugging you - try using a patch or loft to point instead.
Autodesk Industry Marketing Manager UK D&M
Opinions are my own and may not reflect those of my company.
Linkedin Twitter Instagram Facebook Pinterest
Message 3 of 10
JDMather
in reply to: PaulMunford
....or go to the Shaded rather than Shaded with Edges visual style.
Message 4 of 10
emaiolino
in reply to: JDMather
Good afternoon. Thank you both!
But there is a drawback in view of the model, this line remains in the file "IDW" and requires removing the "Visibility" manually in each case.
Esteban Maiolino
Message 5 of 10
Paul-Mason
In the IDW remove the check mark (turn off)ScreenShot013.png TANGENT FACES
Inventor 2023 Pro
HP Z420 workstation
Xeon 3.7Ghz CPU 8 Cores, 64 GB Ram
64bit (The Garbage known as) Windows 10 Pro
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
Message 6 of 10
emaiolino
in reply to: Paul-Mason
Dear Paul Mason,
is not feasible for me to remove the case "tangent faces" as the need to show in this part and the rest.
Obviously I must move each line manually.
Also thank you very much!
Esteban Maiolino
Message 7 of 10
Is it just me or does it seem odd that you see that line when the part is created with an ellipse but not with a simple radius?
Signed,
Curious in Houston.
Message 8 of 10
emaiolino
Dear,
Exactly that is what catches my attention.
The reason that generates that "line" only when it is an ellipse....
Esteban Maiolino
Message 9 of 10
innovatenate
In Inventor 2014, There are new Boundary Patch options you may use to generate this geometry without the tangent edge.
The result should be a smooth face with no edge.
Hope this helps.
Nathan Chandler
Principal Specialist
Message 10 of 10
emaiolino
in reply to: innovatenate
Dear Nathan, good morning.
Thank you very much for your reply, both here and in the support case.
Esteban Maiolino
