Inventor General Discussion
Valued Contributor
shmartin89
Message 1 of 10 (360 Views)
'End if must be preceded by a matching if'
360 Views, 9 Replies
11-23-2012 12:41 AM
Iv attached a picture to show the error & my rule text. I have created the Parameters etc. & the statement includes if & end if. Cheers,Capture.PNG
If Parameter("HEIGHT")=152.4
Parameter("UC_PROFILE")="152.4"
EndIf
If you are finding usnderstanding ilogic difficult, have a go at the online tutorials.
when you created the "UC_PROFILE" Parameter, did you create it as a text parameter?
If not, in the parameters dialogue, use the drop down in the bottom left which by default says "Add Numeric". Select "Add Text" instead.
Distinguished Contributor
waynehelley
Message 2 of 10 (351 Views)
Re: 'End if must be preceded by a matching if'
11-23-2012 01:33 AM in reply to: shmartin89
EndIf
Wayne Helley
Inventor 2013 Certified Professional
Autodesk Inventor Professional 2013
Windows 7 Enterprise, 64-bit
waynehelley
Message 3 of 10 (340 Views)
11-23-2012 03:48 AM in reply to: waynehelley
** Use "End IF', not "ENDIF"
Pasting into IE erased the space.
Wayne Helley
Valued Contributor
shmartin89
Message 4 of 10 (333 Views)
11-23-2012 04:58 AM in reply to: waynehelley
Cheers,
My text in the 'UC_designation' Parameter contains 'x's. E.g - 152.x152x23
Inventor recognises this as an equation, therefor the rule doesnt work. Is there any way around this without replacing the 'x's?
waynehelley
Message 5 of 10 (329 Views)
11-23-2012 05:09 AM in reply to: shmartin89
Wayne Helley
Valued Contributor
shmartin89
Message 6 of 10 (310 Views)
11-23-2012 07:40 AM in reply to: waynehelley
Cheers Wayne.
This is the first time iv started using Rules. If you havent already guessed!
Sandy
Valued Contributor
shmartin89
Message 7 of 10 (306 Views)
11-23-2012 08:17 AM in reply to: shmartin89
Do you know if there is a way in which rules can be run automatically? E.g Everytime the part is updated or saved rather then having to press iTrigger
Cheers,
Valued Contributor
shmartin89
Message 8 of 10 (304 Views)
11-23-2012 08:24 AM in reply to: shmartin89
NVM. Iv added the rule into event triggers.
waynehelley
Message 9 of 10 (248 Views)
11-26-2012 12:20 AM in reply to: shmartin89
I'm not that knowledgeable about triggers I'm afraid, as I have only really been creating rules which I need to run on command, but have a look at this...
http://inventortrenches.blogspot.co.uk/2012/01/creating-basic-ilogic-rule-with-event.html
Wayne Helley
waynehelley
Message 10 of 10 (246 Views)
11-26-2012 12:23 AM in reply to: waynehelley
I just realised NVM stands for nevermind so mevermind my last post also!
Wayne Helley
