Inventor General Discussion
Valued Contributor
shmartin89
Message 1 of 10 (355 Views)
'End if must be preceded by a matching if'
355 Views, 9 Replies
11-23-2012 12:41 AM
Iv attached a picture to show the error & my rule text. I have created the Parameters etc. & the statement includes if & end if. Cheers,Capture.PNG
Distinguished Contributor
waynehelley
Message 2 of 10 (346 Views)
Re: 'End if must be preceded by a matching if'
11-23-2012 01:33 AM in reply to: shmartin89
If Parameter("HEIGHT")=152.4
Parameter("UC_PROFILE")="152.4"
EndIf
If you are finding usnderstanding ilogic difficult, have a go at the online tutorials.
Wayne Helley
Inventor 2013 Certified Professional
Autodesk Inventor Professional 2013
Windows 7 Enterprise, 64-bit
waynehelley
Message 3 of 10 (335 Views)
11-23-2012 03:48 AM in reply to: waynehelley
** Use "End IF', not "ENDIF"
Pasting into IE erased the space.
Wayne Helley
Valued Contributor
shmartin89
Message 4 of 10 (328 Views)
11-23-2012 04:58 AM in reply to: waynehelley
Cheers,
My text in the 'UC_designation' Parameter contains 'x's. E.g - 152.x152x23
Inventor recognises this as an equation, therefor the rule doesnt work. Is there any way around this without replacing the 'x's?
waynehelley
Message 5 of 10 (324 Views)
11-23-2012 05:09 AM in reply to: shmartin89
when you created the "UC_PROFILE" Parameter, did you create it as a text parameter?
If not, in the parameters dialogue, use the drop down in the bottom left which by default says "Add Numeric". Select "Add Text" instead.
Wayne Helley
Valued Contributor
shmartin89
Message 6 of 10 (305 Views)
11-23-2012 07:40 AM in reply to: waynehelley
Cheers Wayne.
This is the first time iv started using Rules. If you havent already guessed!
Sandy
Valued Contributor
shmartin89
Message 7 of 10 (301 Views)
11-23-2012 08:17 AM in reply to: shmartin89
Do you know if there is a way in which rules can be run automatically? E.g Everytime the part is updated or saved rather then having to press iTrigger
Cheers,
Valued Contributor
shmartin89
Message 8 of 10 (299 Views)
11-23-2012 08:24 AM in reply to: shmartin89
NVM. Iv added the rule into event triggers.
waynehelley
Message 9 of 10 (243 Views)
11-26-2012 12:20 AM in reply to: shmartin89
I'm not that knowledgeable about triggers I'm afraid, as I have only really been creating rules which I need to run on command, but have a look at this...
http://inventortrenches.blogspot.co.uk/2012/01/creating-basic-ilogic-rule-with-event.html
Wayne Helley
waynehelley
Message 10 of 10 (241 Views)
11-26-2012 12:23 AM in reply to: waynehelley
I just realised NVM stands for nevermind so mevermind my last post also!
Wayne Helley
