Hello
Coming from a solidworks background, i frequently use weldments, or Inventor's equivalent - frame generator.
Wondering if there was a solidworks 'end cap' equivalent.
See http://help.solidworks.com/2013/English/SolidWorks/sldworks/c_Weldments_End_Caps.htm?id=cd23f257ca8a... for details, essentially a weldment driven and generated part which doesn't need much thinking about.
Be great to get some info.
Joe Banger
Solved by Curtis_Waguespack. Go to Solution.
Hi Joe_Banger,
This question has been asked a lot in the past, so you might find some suggestions in those old threads found by using the search tool:
But to answer your question, Inventor does not currently have a button for doing this, but you can show your support for adding this functionality by giving this IdeaStation idea a kudo at this link:
http://forums.autodesk.com/t5/Inventor-IdeaStation/Easy-end-caps-in-frame-generator/idi-p/4295130
I hope this helps.
Curtis
