Inventor General Discussion
2,122 Kudos
Post 11 of 13
Re: embossing onto multiple surfaces
12-18-2012 10:20 AM in reply to: MikeKovacik4928
MikeKovacik4928 wrote:
... I see it was created on an educational version. I believe that files opened on educational versions corrupt authentic software with the dreaded educational stamp.
It is not possible for one file to "corrupt" another file unless you use that file in another.
The file was created with an authentic student license of the software.
Simply examine the construction technique and then delete the file.
No harm, no foul!
The extrusion must be entirely capped by the offset surface you are extruding to, so offset all surfaces that are needed to cap. When you select the offset surface as the capping surface it will get all of them in the offset surface feature.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
1 Kudo
Post 12 of 13
12-18-2012 11:34 AM in reply to: JDMather
"Accept as solution"
Opened the file, and have seen how you did it.
Have managed to reconstruct myself.
I see you have to be careful of which surfaces you offset or you get error messages.
I see when you select any one of the surfaces which have been offset, while doing the extrude, subtract, to
even though only one is highlighted it takes the whole lot.
If I save the file and keep it as an ipt without bringing it into any iam's or idw's, will I be safe and not get that education plot stamp? The way I understand it from the messages is that as long as I don't mix the model with any thing else (ie keep it separate) the watermark won't appear
Mike
1 Kudo
Post 13 of 13
12-18-2012 11:57 AM in reply to: sam_m
Thanks for your examples and explanations.
I see you used "quilt" on your one example, when I tried to change it to "faces" and selected all the same faces I got an error message.
Conversely on my example when I tried to used "quilt" it wouldn't work, only worked with "faces"
I will look at this command in further detail to see the difference between the two.
I see your use of "sculpt" in the other example, I will look at that command in further detail as well
Mike
