Inventor Forum
Embossing many elements ?
6 REPLIES 6
528 Views, 6 Replies
I'm just starting my adventure with inventor, so sorry if my question is simple,
but I have no idea how to deal with this problem.
Is it possible to emboss multiple elements at once, without selecting each of them separately ?
I got over 2k elements on sketch which are needed to be embosed, it would be really pain to do it manually.
Thanks for help in advance 😄
6 REPLIES 6
JDMather
Can you attach your ipt file here (or at least a screen capture image)?
Sure, the design is in mess due to dimensioning.
I just learned to use multiple copy tool recently.
On screenshot you wouldn't probably see all things so here goes ipt file.
Thanks for interest.
JDMather
Your part is not at the origin.
Pattern Features when possible, not sketches.
You have repeated dimensions that aren't needed.
Edit your sketch and right click and select Show All Constraints.
Zoom in on the small circles.
This is unneeded complexity.
mcgyvr
in reply to: JDMather
This ilogic code works EXCELLENT for "extruding" multiple sketched profiles.. I use it to select multiple "text" elements that I extrude .001" to represent "silkscreening" on my parts.. It can probably be modified to use emboss instead of extrude but maybe extrude will work for you also..
If TypeOf ThisApplication.ActiveEditObject Is Sketch Then
'Do nothing
Else
MessageBox.Show("Activate a Sketch First then Run this Rule", "ilogic")
Return
End If
Dim oPartDoc As PartDocument
oPartDoc = ThisApplication.ActiveDocument
Dim oCompDef As PartComponentDefinition
oCompDef = oPartDoc.ComponentDefinition
Dim oSketch As PlanarSketch
oSketch = ThisApplication.ActiveEditObject
' Create a profile.
Dim oProfile As Profile
On Error Goto NoProfile
oProfile = oSketch.Profiles.AddForSolid
'get user input
oDistance = InputBox("Enter Extrude Distance", "iLogic", ".001 in")
oDirection  = InputRadioBox("Select Extrude Direction", "Up (+)", "Down (-)", True, Title := "iLogic")
oJoinOrCut  = InputRadioBox("Select Extrude Solution", "Join", "Cut", True, Title := "iLogic")
If oDirection = True Then
oDirection = kPositiveExtentDirection
Else
oDirection = kNegativeExtentDirection
End If
If oJoinOrCut = True Then
oJoinOrCut = kJoinOperation
Else
oJoinOrCut = kCutOperation
End If
' Create an extrusion
Dim oExtrude As ExtrudeFeature
On Error Goto NoExtrude
oExtrude = oCompDef.Features.ExtrudeFeatures.AddByDistanceExtent( _
oProfile, oDistance, oDirection, oJoinOrCut)
ThisApplication.CommandManager.ControlDefinitions.Item("FinishSketch").Execute
iLogicVb.UpdateWhenDone = True
Exit Sub
NoProfile:
MessageBox.Show("No closed profile found", "iLogic")
Return
NoExtrude:
MessageBox.Show("No extrusion created, check your inputs.", "iLogic")
Return
Do you mean on a single sketch with multiple items, that you want to emboss onto a single part, or items you want to emboss on multiple parts?
Single sketch with multiple elements (all the same) on single part.
JDMather advice solved problem:
it was possible to copy embos.
