Inventor General Discussion
roger
Message 1 of 5 (222 Views)
Emboss Text Orientation
222 Views, 4 Replies
02-28-2014 06:06 PM
I tried to emboss a logo on both sides of a cylindrical part. Circular face is drawn in xy, extruded in z. I created a work plane parallel to yz on both sides of the part. When I added text to the right side vew of the part (+y to the right) the text was correct. When I rotated the part (z+ to the left) to emboss the other side, the text was backwards. I couldn't find any way to make it read correctly. Is there a way to fix this?
Roger
Hi roger,
Right-click on the work plane that the sketch is on and and choose Flip Normal. This will reverse the negative / positive face of the work plane.
I hope this helps.
Curtis
Curtis_Waguespack
Message 2 of 5 (217 Views)
Re: Emboss Text Orientation
02-28-2014 06:18 PM in reply to: roger
Hi roger,
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
roger
Message 3 of 5 (192 Views)
03-01-2014 06:34 AM in reply to: Curtis_Waguespack
Yes that did it. Thank you so much! Do you teach classes? Thanks, Roger
JDMather
Message 4 of 5 (185 Views)
03-01-2014 06:50 AM in reply to: roger
Curtis wrote the book -
http://www.amazon.com/Mastering-Autodesk-Inventor-2014-LT/dp/1118544862/ref=sr_1_5?ie=UTF8&qid=13936...
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015-SP1 64-bit
roger
Message 5 of 5 (156 Views)
03-02-2014 06:43 PM in reply to: JDMather
I have the Mastering Inventor 2013 Book (which is why I was fiddling with the Emboss feature), and am much honored to have gotten help from the author here!
