Inventor General Discussion
Active Member
raju
Message 1 of 8 (458 Views)
Emboss in assembly
458 Views, 7 Replies
09-20-2012 03:15 PM
Is there a way I can use the emboss feature in an assembly?
We typically laser mark during final assembly and would like to show that as a step in the assembly instructions.
I typically create a sketch with the text and extrude(cut) in the assembly.
It works fine for flat surfaces, but cannot do it for other surfaces.
The one way I can think of doing it would be creating ipart with text and using it in the assembly.
I would rather not do it this way.  Is there any other way to accomplish this with out altering the components (.ipt)?
RobJV
Message 2 of 8 (451 Views)
Re: Emboss in assembly
09-20-2012 03:44 PM in reply to: raju
Without fully understanding the problem, have you tried derived parts?
Active Member
raju
Message 3 of 8 (414 Views)
09-22-2012 06:58 PM in reply to: raju
I know I can use derived parts, but want to avoid doing it.  I do not want to create any new parts.
Employee
stanislav.sedlak
Message 4 of 8 (383 Views)
09-24-2012 03:34 AM in reply to: raju
Unfortunately this is not supported currently. However there's a wishlist logged for this functionality #1458661.
Stanislav
mrattray
Message 5 of 8 (376 Views)
09-24-2012 04:59 AM in reply to: raju
I create a sketch in the flat pattern (I'm assuming sheetmetal) that I use for the actual laser programming, and in the drawing I use the retrieve model sketches command to show the etched lines.
Mike (not Matt) Rattray
Product Support
mercerc
Message 6 of 8 (366 Views)
09-24-2012 07:41 AM in reply to: raju
            Although the emboss command is not available in the assembly features you can create a sketch in the assembly and place text in the sketch. Then you can extrude the text with a cut option. Not as many options as the emboss command but it will do what you want possibility.
Active Member
MadcapPomposity
Message 7 of 8 (225 Views)
09-25-2013 08:01 AM in reply to: mercerc
I hadn't thought of using the Cut command on text, but I just tried it and it worked perfectly! You obviously can't get raised letters with Cut, but it engraves just as well as the Emboss command does.
Using:
Inventor 2013
AutoCAD 2013
Active Member
raju
Message 8 of 8 (217 Views)
09-25-2013 08:39 AM in reply to: mercerc
Thank you.
Raju Penumatcha
Sr. Mechanical Engineer
raju.penumatcha@occfiber.com
[Description: OCC-Email-Sig-Logo]
1700 Capital Avenue, Suite 150
Plano, TX 75075
+1-972-509-1500 ext:108
Fax: +1-972-509-9009
occfiber.com
Connect with us...
Facebook | Twitter | LinkedIn
