Inventor General Discussion
Active Contributor
dave
Message 1 of 8 (283 Views)
Emboss compound surfaces
283 Views, 7 Replies
09-24-2013 08:10 AM
Hello folks,
I'm stuck on a few different emboss cases,  If somebody can please help me get "unstuck" on these, I'd appreciate it.  Thanks.
The following examples are just dumbed-down models to learn from.  If it matters - I'm actually embossing patterns on more complicated parts - not text on primitive shapes.
Case 1:  Emboss across several surfaces.  Please see attached file "Wrap Emboss 1".  I can wrap to a face - but not all three faces on the solid that I want my "TEST TEST TEST" message to span across.  My embossed text goes off into space - it doesn't wrap around the edge of the solid as desired.
Case 2: Emboss text (or some other arbitrary shape) onto a single (but compound) surface.  Please see file "Compound Emboss 2".  If the curvature of the part isn't significant - there are a few ways to fake/trick out the model to get a passable result.  BUT - when the curvature of the surface is significant relative to size of the text/pattern to be embossed - I haven't yet found a solution that doesn't wildly distort the embossed feature.  As the surface of the part is compound - I can't use the "Wrap to Face" option without an error.  The resulting embossed feature is unacceptable.
Any advice or thoughts that might be shared with me will be greatly appreciated.
Thanks.
Dave
Valued Mentor
mpatchus
Message 2 of 8 (276 Views)
Re: Emboss compound surfaces
09-24-2013 08:19 AM in reply to: dave
What version are these files?
Mike Patchus
Inventor 2012 SP3 ~ Vault Pro 2013
Lenovo D20 Workstation Intel Xenon E5640@2.67GHz (2)
Win 7, 24gb RAM, NVIDIA Quadro FX 3800
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. :smileyhappy:
Active Contributor
dave
Message 3 of 8 (273 Views)
09-24-2013 08:23 AM in reply to: mpatchus
Inventor 2014.  Trouble opening them?
Valued Mentor
mpatchus
Message 4 of 8 (269 Views)
09-24-2013 08:27 AM in reply to: dave
Always a good idea when posting files, to include what version of the software you are running.
Many folks are still running previous versions and cannot open the 2014 files.
Nothing worse when trying to help someone out than downloading the files, only then find out that you can't provide any assistance because they are a newer version.
Mike Patchus
Active Contributor
dave
Message 5 of 8 (223 Views)
09-25-2013 06:09 AM in reply to: mpatchus
OK.  Thank you Mike.  Were you able to open the IV2014 files?  If not, is there some way that I can save the file for compatability?  (I don;t see any option like that in the save as dialog.  Maybe somewhere else?)
Looking forward to your advice on the issues I'm having with the embossed features I need to create.
Dave
Valued Mentor
mpatchus
Message 6 of 8 (216 Views)
09-25-2013 06:51 AM in reply to: dave
There is no backward compatibility with Inventor files.
You'll need to wait for a 2014 user to assist with this one.  SORRY
Mike Patchus
Valued Mentor
GSE_Dan_A
Message 7 of 8 (211 Views)
09-25-2013 06:57 AM in reply to: dave
dave, for future reference, try posting screen grabs of those parts you posted as well.  It gives Users a chance to re-create your scenario in different versions of Inventor and post their results/ workflow.  As a fairly new user to Inventor, I can not help you with your problem.  Good luck!
GSE Consultants Inc.
Windsor, ON. Canada
Active Contributor
dave
Message 8 of 8 (197 Views)
09-25-2013 08:28 AM in reply to: GSE_Dan_A
GSE_Dan,
Great recommendation.  Here are screen grabs of the two IV models:
Wrap Emboss 1 (Trying to wrap embossed feature around adjacent planar and cylindrical faces.)
Compound Emboss 2: (Trying to emboss a single compound surface without unacceptable distortion.  Wrap to face option not permitted as surface is not planar, cylindrical, or conical.)
Post to the Community
New Post
Need installation help?
