It's been a little while since I did this, but this is what I remember. If
these other cells had been used for anything previously and then had the
data deleted from them, IV still brings them in. I copied and pasted the
cells that I wanted into a new worksheet with the upper left corner of the
data in cell A1, saved it, and imported the file. This solved the problem.
There must be more to it, because I just did a quick test, and this time, I
was able to import a file without cells that had values deleted from them.
-Mike
