Inventor Forum
Embedded parameters question
3 REPLIES 3
pquenzi
157 Views, 3 Replies
If I have a part controlled by an embedded spreadsheet and use "save as" to make several new parts from it each with different dimensions, should I be able to insert all of these new parts into an assembly without problems?
When I do this Inventor crashes unless I delete the spreadsheets from the new parts.
Thanks.
Phil Quenzi
3 REPLIES 3
in reply to: pquenzi
Embedded yes, linked no.
Not sure why you get the crash but your logic is correct.
Post the part in CF and we'll have a look.
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"pquenzi" wrote in message
news:f14efbb.-1@WebX.maYIadrTaRb...
new parts.
> Thanks.
> Phil Quenzi
We've always has issues with embedded spreadsheets. Never quite repeatible enough to be able to log a solid defect though.
pquenzi
In my case the part was a gear. I even made a new gear from scratch and got the same crashes. I'll just continue to remove the spreadsheets from the parts as it's not that big a deal to do.
Phil Quenzi
