Embedded yes, linked no.
Not sure why you get the crash but your logic is correct.
Post the part in CF and we'll have a look.
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"pquenzi"
wrote in message
news:f14efbb.-1@WebX.maYIadrTaRb...
> If I have a part controlled by an embedded spreadsheet and use "save as"
to make several new parts from it each with different dimensions, should I
be able to insert all of these new parts into an assembly without problems?
> When I do this Inventor crashes unless I delete the spreadsheets from the
new parts.
> Thanks.
> Phil Quenzi
