Inventor Forum
Elevation symbol
7 REPLIES 7
Message 1 of 8
4913 Views, 7 Replies
Elevation symbol
I'm looking for an elevation marker to add to an Inventor drawing, I need something similar to what is currently available in AutoCAD's design centre. Does anyone know if there is one available in Inventor 2013 ?
7 REPLIES 7
Message 2 of 8
Ryan.Martinez
You could create your own sketched symbol. see this pdf
http://download.autodesk.com/us/inventorprofessional/pdf/SketchedSymbols_stacking.pdf
P.D.S. 2015
P.D.S. 2016
Message 3 of 8
in reply to: Ryan.Martinez
So Inventor does not have a library of symbols for use like in AutoCAD then ? Thanks for your PDF link, to me it seems like placing an elevation symbol (for example) into a drawing should take seconds without the need to spend unnecessary time creating the symbol myself ? ? It would be good to see Autodesk address this one for the next release.
Message 4 of 8
Ryan.Martinez
create it once in your template file and it will be there everytime you use that template to create a drawing.
P.D.S. 2015
P.D.S. 2016
Message 5 of 8
You can insert acad drawings into a sketch. So you wouldn't even have to draw it. Just save what you want in autocad then import it into inventor.
P.D.S. 2015
P.D.S. 2016
Message 6 of 8
Thanks yes, I still think the whole idea of a standard annotation and architectural symbols library being completely absent from Inventor needs addressing - a symbols library should be available as standard with the option to add to this with custom sketched symbols as you have suggested.
Message 7 of 8
Ryan.Martinez
I see your point but inventor is a mechanical design tool, not architectural. Maybe the factory design package or revit it would have the symbols your looking for, just a guess.
P.D.S. 2015
P.D.S. 2016
Message 8 of 8
You can create your own level symbol using a sketched symbol, store it locally and share with your other computers.
I reckon, this might be the easiest and fastest way for you to solve this problem.
You can use sketched symbols for many purposes and I think learning this technique really helps you in the long run.
I know this is an old post but hopefully this helps new people searching for the solution for this question!
