Inventor Forum
Elastic part with elastic property in an assembly..
6 REPLIES 6
cats_eye
859 Views, 6 Replies
Hello everyone..
I am designing a product using Autodesk inventor professional 2013.. I have a problem in setting the design of the part for the elastic element since i cannot mimic the behavior of the actual part. I have tried disecting the part into pieces and assembled it but still i cannot get a precise result.
Is there a way that we can make an elastic part with the actual elastic property in an assembly??
Kindly advise..
6 REPLIES 6
skintsubby
in reply to: cats_eye
cats_eye
I suggest you try over at the Inventor forum
http://forums.autodesk.com/t5/Inventor/ct-p/70
Mark
mdavis22569
I wouldn't stay elastic ..but you could make it adaptive ..and it'll adjust as you adjust it ...
Mike Davis
JDMather
By making a adaptive parameter (for example changing the radius of an arc) you can make a part "flex".
Can you attach your assembly here?
cats_eye
in reply to: skintsubby
Thanks for the information..
cats_eye
in reply to: mdavis22569
I am using adaptive property for those inserted assemblies in my project assembly but can i also use it to my inserted part?
cats_eye
in reply to: JDMather
Thanks for the reply..
I will try to send you the assembly in private because the design of the assembly i am pertaining to is a classified product design owned by our company..
