A (hopefully) quick question concerning multibody parts and assemblies created from them.....
I create a multibody part called MB with multibodies named 'A' and 'B'.
Using the Make Components command I create componets A and B, and an assembly of A and B and call it AB.
I understand (and am a great fan of) that if I edit the multibodies A or B in MB, then the corresponding changes will be made to the newly created parts A and B in AB.
my question is this, does (or should) this work the other way around? - if i place a hole in part B, should this change the original multibody? It does not on my machine but I just wanted to make sure I was not missing something!
thanks
Solved by JDMather. Go to Solution.
No.
