Inventor Forum
Editing hatch region
6 REPLIES 6
KevinPinks7697
442 Views, 6 Replies
I have attached a hatch to a sketch on a layout view, but now I would like to edit the hatch or remove it and start again. How do I do this?
Thx
Kev
6 REPLIES 6
wim 3dvorm
in reply to: KevinPinks7697
I don't know if this is what you looking for and also a little bit late, select the hatchbutton and then the hatch, so you can change or disable it.
I can't select the Hatch button, the "Fill/Hatch Sketch Region" button is greyed out when I am in the sketch
wim 3dvorm
Are you sure you are in the right sketch, also in the sketch mode you can select other sketches for moving.
All I am trying to do is edit the scale of the hatch in the hole?
Thx
Kev
wim 3dvorm
I see the green sketch line, but can't see projected geometry, did you use projected geometry?
I've tried do the same, see attached jpg.
If you sketch one line in a sketch you can use the hatch button, so it is strange that your button is greyed out.
Do you enter the sketch by double clicking on the sketch line?
I got it to work now, thanks
Kev
