I cannot edit a file after the initial save. I get the attached error. What do I need to do? Any help would be greatly appreciated.
Brent
You might start by moving this thread to an Inventor forum, you'll probably find better answers there.
Short answer: Content Center files are not editable.
Long answer: Inventor will not allow editing of files in a folder that is currently defined as Content Center files. The CC files location is specified by Application Options > File > Default Content Center files, but can be overridden by the active project (Folder Options > Content Center Files). If files are moved to a different folder not defined as CC files, they are editable. If the active project is changed to define a different location for CC files, the files in the original location are editable.
Does that help?
Sam B
Inventor Professional 2015 SP1 Update 1
Windows 7 Enterprise 64-bit, SP1
HP EliteBook 8770w; 8 GB RAM; Core™ i7-3720QM 2.60 GHz; Quadro K4000M
Yes! Thank you so much! I created a working folder outside of the CC location. I'll use the CC location for released files. If I may, I would like to ask another question. I wanted to try to explore the Vault as a location for documentation storage/control. I'm a single user running Inventor on a single computer. When I try to log-in to the Vault with the default log-in information (screenshot attached), I get the attached error. Again, any information you could provide would be appreciated. Thanks in advance. Brent
We don't use Vault, so I can't help you with that. Someone else will have to jump in. If nobody does, I'd suggest starting a new thread with a good descriptive subject line. You might also try the Vault forum.
Sam B
Have you installed and configured ADMS on your machine?
