Good morning, I am learning quite a bit about Parts Lists, BOM's and editing the Content Center. The odd time when I am "refreshing" the family table, I get an error saying that the hardware "failed" to update? Why would this happen and how can I fix it?
Hi!
I don't know if it is your case but... you can't edit parts from the original Content Center.
You can publish parts or, copy Original Content Center components, and these copied or published parts are the only ones you are able to edit.
Did you find this reply helpful ? If so, use the Accept as Solution or Kudos - Thank you!
I think we would need more information about exactly what you are trying to edit and how. maybe some screen shots? Do you have read/write access to the library you are editing?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
