Inventor General Discussion
129 Kudos
Post 1 of 20
Edit image Family Category in Content Center
415 Views, 19 Replies
03-27-2008 09:28 AM
Hi all,
How can i load an image in a already created family category of my Content Center library??
I forgot to load an image. and now i cannot load new one.
Why not??? Please see the picture.
Regards
Maria Manuela Pinho
Application Specialist
Cadtech / Asidek - Autodesk Gold Partner
Autodesk Inventor Professional 2015 | Lenovo W520
Ok,... I've looked at this again in 2013 IV Pro, and danged if it ain't ME proved wrong.  Existing categories, even in a read/write library with full Administrator's permissions, cannot be edited.  Not only the image, but the entire category.  Creating a new category gives you full options, but once it is created no dice.  This includes previously created custom categories.  AND this is not in "Merged View".
And.... here's why.:
I'm going to look into how this can be done from the server using this help page.  If I can figure it out I'll report back.
Valued Contributor
0 Kudos
Post 2 of 20
Re: Edit image Family Category in Content Center
03-31-2008 11:32 PM in reply to: MariaManuela
Hi MPinho,
Created category cannot be edit any more. It need to load image while creating category.
Corrine
8 Kudos
Post 3 of 20
04-01-2008 04:17 AM in reply to: MariaManuela
Might be a good idea for Autodesk to fix this problem.
*Dennis Jeffrey
Post 4 of 20
04-01-2008 07:04 AM in reply to: MariaManuela
It is fixed in 2009
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
Instructor/Author/Sr. App Engr.
AIP 2008 SP2, AIP 2009 PcCillin AV
HP zv5000 AMD64 2GB
Geforce Go 440, Driver: .8185
XP Pro SP2, Windows XP Silver Theme
http://teknigroup.com
wrote in message news:5890899@discussion.autodesk.com...
*Dennis Jeffrey
Post 5 of 20
04-01-2008 08:41 AM in reply to: MariaManuela
In 2009 Content Center Editor, set the library view to your read/write
library. Right click on the appropriate category and select category
properties. From there you can browse to an appropriate bitmap. See
attached.
HP zv5000 AMD64 2GB
Distinguished Contributor
2 Kudos
Post 6 of 20
11-14-2012 04:42 PM in reply to: *Dennis Jeffrey
Does not seem to be fixed in 2013. I just tried. "Load alternate image" is definitely greyed out. Library is read/write.
I may stand corrected of course...
Regards.
Inventor Professional 2014.
Windows 7 64 bit.
843 Kudos
Post 7 of 20
11-15-2012 05:50 AM in reply to: PaulB108
It works on mine.  Not sure why you are unable to do this.
(RIP Dennis)
ChrisB / Twitter
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cadtipstricks.wordpress.com//
2 Kudos
Post 8 of 20
11-15-2012 02:14 PM in reply to: MariaManuela
Ok then. I stand corrected.
Care to give me a brief procedure? I may be able to troubleshoot my own that way...
Regards.
Windows 7 64 bit.
Valued Contributor
0 Kudos
Post 9 of 20
06-13-2013 03:38 AM in reply to: MariaManuela
I am aslo not able to load alternate images for category properties. Content Center is in the Vault professional and we use inventor 2013. All updates are installed.
Where is the problem?
Edit: it works fine for famiily properties
TG
Best regards
TG
Autodesk Inventor/Vault Professional 2015
843 Kudos
Post 10 of 20
06-13-2013 04:27 AM in reply to: tegstette
ChrisB / Twitter
