Ah, not so fast Rado - I think he can do it 🙂
First - make sure all of the o-rings are using the same material.
Second - Edit your standard style, go to the Material Hatch Pattern Defaults
tab
Third - Add your o-ring material to the list and set it to the desired hatch
pattern, save changes and exit the style dialog
Fourth - Multi-select the hatch patterns in your drawing view(s),
right-click and select Pattern > By Material
That should do it.
Hope that helps,
Andrew Faix
Product Designer
Autodesk Inventor
DIGITAL PROTOTYPING - Got it?
wrote in message
news:5793308@discussion.autodesk.com...
I'm afraid there's no easy way how to change hatch for all your instances.
I believe it could be better if there would be the ability to select a
hatch/hatches and apply the desired hatch style through styles drop down
menu.
I've logged it as wish # 1017956.
Rado
