Inventor Forum
Edit Extrusion Profile
3 REPLIES 3
TomBarosso3248
2399 Views, 3 Replies
Sketch1 is the outside profile for a plate. From it I create Extrusion1 and constrain it in an assembly. If I later decide that a cutout is needed in the center of the plate, I edit sketch1 to show it. But when I'm done, I can't "unselect" my original profile and extrude the new shape. The new geometry in sketch1 is hidden by the previous body and I can't unselect that profile.
So I have to delete extrusion1 and start over. When I return to my assembly I have to redo the constraints that were placed relative to extrusion1.
Any help appreciated.
Tom
3 REPLIES 3
JDMather
in reply to: TomBarosso3248
Can you zip and attach the file?
Are you holding the Ctrl key?
Why not just do it the way they would in the shop.
Sketch-1 is your main plate shape, then edit the IPT and add a second sketch on
the top for your cut-out. This way your plate will retain the
constraints.
Try to do your modeling following the same steps as
the shop floor will follow.
IV2009-Pro Sp1
Dell 670 dual
Xeon - 3.2
3gb memory, SCSI320-15k rpm
XP-Pro, sp3
Quadro FX3400:
Driver: 174.06 Direct3D
SpacePilot Rel V: 3.6.7 Dvr V: 6.6.1 Firmware
3.12
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Sketch1
hidden by the previous body and I can't unselect that profile. So I have to
the constraints that were placed relative to extrusion1. Any help appreciated.
Tom
Holding the control key works, thank you.
Tom
