Its not just for that dimension. Its a setting that sticks. Its the same as
doing it in options.
Drew Fulford, B.A.Sc. Systems Engineer
Solid Caddgroup Inc, Burlington, Ontario
Phone: (905) 331-9670 Fax: (905) 331-7280
Member of the Autodesk Discussion Forum Moderator Program
Check out my MDT & Inventor FAQ @ http://www.mymcad.com/
"Kirk A." wrote in message
news:3fe70c80$1_1@statler...
> Drew,
> That just works for that one dimension, right??
> What I am seeing is the Edit Dimension box will start appearing when I
place
> a dimension. I can then go to Tools>Application Options,Sketch Tab and
the
> "Edit Dimension when created" box will be checked. I didn't check it. I
> always want to sketch with this un-checked.
> From what I see, the context menu you are talking about does not effect
this
> switch.
> Kirk
> "Drew Fulford" wrote in message
news:3fe6fd98_4@statler...
> > Before you place a dimension, RMB and you will see the edit dimension
> option
> > there. Most likely you have toggled the switch here as opposed to in the
> > options.
> > - Drew
> > news:3fe6fcea$1_3@statler...
> > > Morning all,
> > > I had noticed since about R6 that while I was sketching, the "Edit
> > Dimesions
> > > when Created" (Applications Option, Sketch tab) would get toggled
"ON".
> I
> > > always draw with this off. I can't explain what makes it come on, it
> just
> > > does. It is a pain to have to go and turn this back off.
> > > I think I remember seeing something about this posted a long time ago.
> > > Anyone else stillseeing this?
> > > How about a fix.
> > > Inventor R8
> > > Dell 4550
> > > WinXP Pro
> > > P4, 2.8 Ghz, 1G
> > > Quadro 900 XGL
> > > nVidia v6.14.10.4403
> > > 1280x1024, 32 bit
