Inventor Forum
Edit dimension when created
10 REPLIES 10
Message 1 of 11
712 Views, 10 Replies
Tools\Application Options\Sketch
"Edit dimension when created"
I always use this feature enabled, but for some reason,sometimes, It decides
to disable itself...can`t see exactly the pattern for when this happens, no
big deal (I saw it in release 5/5.3 also) but it`s a bit frustrating.
Jorgen
10 REPLIES 10
Message 2 of 11
I have the same problem and had it in the past too!
Alon
"JGH" wrote in message
news:38AEDAC04E75152E8ED31A7E9A98BAE5@in.WebX.maYIadrTaRb...
decides
no
> Regards,
> Jorgen
Message 3 of 11
Same thing happens to me also, from Inventor 5.3 to 6.0 SP1.
Message 4 of 11
Some people have problems with losing settings. I think a reinstall or maybe
an SP was the remedy. Meanwhile you can always toggle it on/off while
creating dimensions. After picking your first geometry, before placing the
final location of the dim, RMB and you will see "Edit dimension". You can
pick this to toggle the feature.
K
decides
no
> Regards,
> Jorgen
Message 5 of 11
It still does it to me after going from 5.3 to 6, then a move to a newer
machine with a fesh install of the OS, then SP1.
It doesn't bother me much at all when the setting disapears, just curiuos as
to whjy it does it.
Message 6 of 11
If you crash before exiting correctly the settings will not be saved. I
have 5.3 and 6 on the same machine and the settings stick. Best thing to do
is set them, exit then set them in the other version and exit. Seems to
stick here at least...
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
http://www.sdotson.com/faq.html
"AUGUST PANNING" wrote in message
news:BCE01C22502FAA5921B8FE17A2981458@in.WebX.maYIadrTaRb...
as
> to whjy it does it.
Message 7 of 11
Still does it after closing IV properly. 😞
"Sean Dotson" wrote in message
news:CA079DB5F8CD1AAC17D0389409045465@in.WebX.maYIadrTaRb...
do
> Sean Dotson, PE
curiuos
> as
> > to whjy it does it.
Message 8 of 11
gnrnr
The only time we see settings disappear is when another user logs onto the machine. When that happens, everything goes back to default settings (template directories etc). I'm guessing that to fix this we need to make the default changes while logged in as the administrator. This resetting occurs everytime another user logs in and they open Inventor.
Regards
Steve
PS. Sean thanks for the line break tip.
Message 9 of 11
Rbax2014
my edit dimension when created  is checked and still does not work, I,m using 2015 inventor.  Is anyone else having this issue?
Message 10 of 11
JDMather
in reply to: Rbax2014
Attach some screen capture images.
Your problem sounds entirely different than the problem in this thread - if you do in fact have it activated, yet it does not work.
In the original problem I most often would see users experience this behavior when they were working fast and indavertently unchecked Edit Dimension when using the right mouse button (the screen was a little different back then than my attached image.
Most of the Tools>Application Options settings do not have a RMB access as well.
Message 11 of 11
Rbax2014
in reply to: JDMather
thank you that was the fix
Man Very Happy
