my edit dimension when created is checked and still does not work, I,m using 2015 inventor. Is anyone else having this issue?
Attach some screen capture images.
Your problem sounds entirely different than the problem in this thread - if you do in fact have it activated, yet it does not work.
In the original problem I most often would see users experience this behavior when they were working fast and indavertently unchecked Edit Dimension when using the right mouse button (the screen was a little different back then than my attached image.
Most of the Tools>Application Options settings do not have a RMB access as well.
