I currently have to palce a lot of parts from the content center into an assembly and miss essential imates for easy placement.
I am using IV2010 at the moment and have no clue where to start.
I have tried copying a new instance of a part into a new library. I then placed this component in the assembly hoping I could add iMates to it in the assembly environment. But when I want to save I get the message that the part has not been checked out for me to use even though I have read/write access to the library.
So a couple of questions here:
As files in the CC are saved in a datapase and not as part files, can imates be included in that database?
Do I really need to recreate the part from scratch, and then publish it to the library?
How would it be possible to open up a CC file like in the part edit mode in an assembly?
Any reply is greatly appreciated...
Magnus
Solved by Tradeiteasy. Go to Solution.
The problem is one of the problem types most of us love...one that solves itself.
The link to the explanation is the following:
Hope it helps anyone with the same issues.
