We just switched from Inventor 2011 to 2012 and are seeing the following when editing assembly constraints. When you edit the constraint the offset value shows up in red and if you hit OK without changing the value you get this error: The expression evaluates out of the expected range. If the value is changed there is no error and if you change the parameter input display setting to "Display as value" there is no error.
Is this "just the way it is" or is there a way to prevent the error from popping up?
TIA
