I wish to edit a file in the library usig Inventor 2011 -- this is shown as read only
is this possible? If so, how do I go about it?
Solved by rdyson. Go to Solution.
Solved by john.laidler. Go to Solution.
Set a project active that doesn't designate that folder as a library.
@jclaidler wrote:Set a project active that doesn't designate that folder as a library.
OR move the file to a different folder, make changes, move back
