i'm looking for a command,activex,plugin,vba ,c++ ,any external program or way of that help me to cut a solid objetc in
multiples slices using paralel and equidistants cutters planes, like a
tomography
More information is needed.
What version of Inventor?
What is the purpose of the sections?
Can you attach the ipt file here?
Hi Dear;
inventor 2011 or any version.
i need for multiple slice to 3D object each slice is 1 mm thickness and we will convert to 2D views each parts and align after slice,and they will cut by laser from 1mm thickness steel sheet.
123make from Autodesk might be a solution
