I'm trying to create earthing braid on my content center, but I'm bumping on a little (big) problem ...
The iPart I created work quiet fine, but when I export it to the content center it don't wotk at all.
For the explaination, please see the sreen capture and text below :
The collumn "Member" is the filename and is generated according to the "Numero de pièce" (Project name), the Dpattes (Dimension between the pad) and the "N° de plan" (drawing number) so it cannot be two identical falenames.
The collumn "Observation Fr" and "Observation An" are collumns on the bill of material and depend of the collumn "N° de plan" who must be enter manualy.
The Collumn "Dpattes" as to be enter manually and must be between 100 and 300.
When I use the iPart normaly it work fine, I can enter the "Dpattes" and the "N° de plan"
But when I export the iPart in the content center, Inventor tells me that different members can have the same name, he is wrong ...
And the collumn "N° de plan" cannot be enter manually anymore.
Is there a solution to force Inventor to recognize there will be no identical names ?
And is there a solution to enter text manualy in a content center part ?
Thank you.
