Inventor General Discussion
Active Member
aldyatma
Message 1 of 11 (613 Views)
dynamics simulation menu
613 Views, 10 Replies
09-26-2012 06:44 PM
hy,
I have installed inventor 2011 on my laptop, but the dynamic simulation menu does not appear even though I 've been many times to install it.
how do I bring it up ?
best regards,
aldyatma
note: here is the screenshot
Hi Aldyatma,
  That /echo switch isn't going to work, since there probably aren't any comments in the *.exe.
  I thought I could use process explorer to find out what keys are written when using RegisterDynamicSimulation.exe, but there are so many keys written, it is difficult to figure out which one is needed in order for the Add-In to register.
  The only thing I can recommend is a clean un-install then re-install at this point.
  My apologies I couldn't be much more help on this.
Sincerely, -Hugh
Employee
MingweiGao
Message 2 of 11 (607 Views)
Re: dynamics simulation menu
09-26-2012 08:30 PM in reply to: aldyatma
hi aldyatma,
Did you loaded DS add-in in Tools-->Add-Ins-->Dynamic Simulation?
Refer to attached picture.
Mingwei Gao
Software QA Engineer
Inventor Quality Assurance Team
Active Member
aldyatma
Message 3 of 11 (596 Views)
09-26-2012 09:09 PM in reply to: MingweiGao
I 've been looking at the add-in manager, but I still did not find it. In addition, the simulation menu there is only stress analysis....
Employee
henderh
Message 4 of 11 (557 Views)
09-27-2012 12:42 PM in reply to: aldyatma
Hi Aldyatma,
  If the Dynamic Simulation add-in isn't appearing in the Add-Ins manager there was likely a permissions issue during registration / installation.
  Could you try the following to manually re-register it?
0)  Close down Inventor and ensure the process is not running in Windows Task Manager
1)  Lauch the command line window (windows start menu => type 'cmd' and OK)
2)  Navigate to Inventor's Bin folder in the command line window (e.g. cd "C:\Program Files\Autodesk\Inventor 2011\Bin")
3)  Type "RegisterDynamicSimulation.exe /install" (you may be able to see the process appear for a second in Task Manager)
4)  If that doesn't work you can try re-registering all of Inventor and it's add-ins by typing "Inventor.exe /install"
  Hope this helps.
Best regards, -Hugh
Hugh Henderson
Simulation QA Engineer
DLS
Active Member
aldyatma
Message 5 of 11 (540 Views)
09-27-2012 04:13 PM in reply to: henderh
Dear hugh ,
Can I see a picture for every step that you provide? I was a bit confused when I did not see it..
Employee
henderh
Message 6 of 11 (535 Views)
09-27-2012 04:27 PM in reply to: aldyatma
Hi aldyatma,
  I tried to capture images of the steps in the file attachment.  Please make sure you have Administrative priviliges, turn UAC off, and disable any firewalls or Anti-Virus.
  I didn't have R2011 Inventor installed, so the screen captures are from R2013 Inventor and Windows7 O/S.
Thanks, -Hugh
Hugh Henderson
DLS
Active Member
aldyatma
Message 7 of 11 (532 Views)
09-27-2012 04:55 PM in reply to: henderh
Dear Hugh,
I have followed the instructions you gave, but the dynamic simulation menu still does not appear. Do you have any other way to solve it?
Employee
henderh
Message 8 of 11 (523 Views)
09-27-2012 08:54 PM in reply to: aldyatma
Hi Aldyatma,
  Thank you for providing the images.  I believe you performed the commands correctly, but DS is still not registering. I'm not at my machine at this time, and will return to the office Monday.
  Another thing to check for are missing files on disk.  Can you verify if there exists a file in your /bin directory called DynamicSimulation.dll or something similar?
  If this dll file exists, we can move on and try using an "/echo on" switch in the command line to see why the registration process is not occuring properly.  I suspect certain registry keys are not being created or read.
  I hope this helps..
Best regards, -Hugh
{Edit: echo on, not off}
Hugh Henderson
DLS
Active Member
aldyatma
Message 9 of 11 (510 Views)
09-27-2012 09:12 PM in reply to: henderh
dear hugh,
I have verified that DynamicSimulationdll and DynamicSimulationResdll contained in the /bin folder. But I do not understand about the command " / echo" , can you explain it?
Employee
henderh
Message 10 of 11 (472 Views)
10-01-2012 03:02 PM in reply to: aldyatma
Hi Aldyatma,
Sincerely, -Hugh
Hugh Henderson
DLS
