I have to admit I never have used, nor do I use this particular feature. With that in mind I followed your step by step procedure you posted in your previous e-mail. It worked without a hitch. The only axis that I could not rotate was the Z axis due to the dimensional constraints placed against the reference/projected edges of the cube.... Delete those and it will rotate the Z axis as well....(if that is the axis that you are trying to rotate).
