Inventor Forum
dynamic stress simulation
2 REPLIES 2
440 Views, 2 Replies
is their a possibility to applay stress like dynamic i have a shaft that has a pully on it , its conectet on an old way
not with a tight fit so it shrinks on it but it works wit a small cut in the shaft where its bolted with just a tiny metal plate.
at this place will be a stress concentration and i wanne see how the noth effect is when their is a dynamic load on it cause if i put a static load on it i know the shaft can handel it but i real life it has broken couple of times so this is what i want to investigate shaft.png
i hope you understand my question and help me  kind regards
2 REPLIES 2
JDMather
Can you test the assembly in the Dynamic Simulation environment and output time-steps to FEA for Motion Loads Analysis?
I don't see any twisting forces on your shaft - how is the shaft used in an assembly?
in reply to: JDMather
on the shaft is a pully that guides a  chain but somtimes the  chain blocks and so the motor + reductor builds up tention until it releases . i asume that the worst place is when the pully is in that direction when the pulling force is in a perpendicular direction with the flat surface  so the shaft is getting "pulled open" if you get what i mean . i think multiple times of this force will tear the shaft at the red line in the picture. this is how i wanne simulated it
can i do this with inventor or do i need the multi physics for it ?
in other words their isnt going to be a twisting force cause the chain guides trough it only the friction between the chain and pully is going to make it turn around but this forces are neglecteble
Kind regards
