I am setting up a simulation where balls are moving on tracks and sprockets and chains are also employed. Everything is running fine except for a certain subassembly within a flexibly subassembly. I have automatic joint creation turned off. Within simulation, is there no way to tell Inventor that the entire child subassembly is all welded together and to treat as a single part without expressly using welded joints on every part in that child sub?
Imagine a rod in a hole that rotates - only the rod is made of multiple parts. Do I have to apply joints to all the parts that make up that rod so that they all rotate together? Sorry - I can't attach parts.
Rob
Solved by RobJV. Go to Solution.
