Inventor mention the “Repair Redundancies command” in the pop up window, see picture attached. But I did not find this command existing. Please advise this command exists in general.
Solved by JDMather. Go to Solution.
What book are you using to learn Inventor Dynamic Simulation?
I use Help. If you could reccomend a book I would appreciate it.
So far I have a row of mechanisms perfectly working as Drive Constrain but
neither automatic nor manual transforming to Dynamic Simulation did not help
making them working.
There is only one book.
And unfortunately, in my experience the Inventor Help system will not have enough information and the Inventor DS tutorials are garbage.
