Hi guys, Maybe I'm just overlooking something really simple.
I have a robot that I am animating in Dynamic Simulation. I have Imposed motion on each of the relevant joints, and can run the simulation nicely.
The problem occurs when I "Publish to Studio" I loose all functionality and the robot stays still in the Studio environment.
What am I missing? Thanks!
-Chris
Solved by JDMather. Go to Solution.
Have you done this previously with one of the tutorials and know the process?
Set the animate favorites parameter to the same number of steps as in the Dynamic Simulation.
(I'll have to look up the exact terms, tutorial and screen captures of steps in a little while if you can't locate them yourself.)
Every time I run a search for some problem I have, its always JDMathers with the solution that works.
Thanks for the tip, it was infact the animate favorites paramater.
Many thanks!
-Chris
Regards fellows. My question is not the same as your...I am following the original question made by Xchrisgrassx because it is in the same line as my doubt. Mine could be a silly simple task I am forgetting hence ...I CAN NOT ENABLE DYN SIM environment from the ENVIROMENT PANEL and then to the BEGIN TAB as says the tutorial I am trying to follow. I am having a go the tutorial with a saw machine.
I do not really know what I am missing because I can not get the environment enable, is not just with this particular IAM file, with all another files happens the same. Please I need guidance about this. Thanks in advance...
