Inventor Forum
Dynamic Simulation error
5 REPLIES 5
xchrisgrassx
531 Views, 5 Replies
Hi guys, Maybe I'm just overlooking something really simple.
I have a robot that I am animating in Dynamic Simulation. I have Imposed motion on each of the relevant joints, and can run the simulation nicely.
The problem occurs when I "Publish to Studio" I loose all functionality and the robot stays still in the Studio environment.
What am I missing? Thanks!
-Chris
5 REPLIES 5
xchrisgrassx
in reply to: xchrisgrassx
Sorry for the bump guys, but im stuck here
JDMather
Have you done this previously with one of the tutorials and know the process?
Set the animate favorites parameter to the same number of steps as in the Dynamic Simulation.
(I'll have to look up the exact terms, tutorial and screen captures of steps in a little while if you can't locate them yourself.)
xchrisgrassx
in reply to: JDMather
Every time I run a search for some problem I have, its always JDMathers with the solution that works.
Thanks for the tip, it was infact the animate favorites paramater.
Many thanks!
-Chris
BramosB
Hi JDMather, I am following the original question made by Xchrisgrassx which is in the same line as my doubt. It could be a very simple task I am forgetting but I CAN NOT ENABLE DYN SIM environment from the panel environment and then begin tab as says the tutorial I am trying to follow. I am having a go the tutorial with a saw machine. I do not really know what I am missing because I can not get the environment enable, is not just with this particular IAM file, with all another files happens the same. Please I need guidance about this. Thanks in advance...
BramosB
Regards fellows. My question is not the same as your...I am following the original question made by Xchrisgrassx because it is in the same line as my doubt. Mine could be a silly simple task I am forgetting hence ...I CAN NOT ENABLE DYN SIM environment from the ENVIROMENT PANEL and then to the BEGIN TAB as says the tutorial I am trying to follow. I am having a go the tutorial with a saw machine.
