Inventor General Discussion
CAD-One
Message 11 of 16 (240 Views)
Re: DXF
09-30-2012 05:50 PM in reply to: BLHDrafting
Great input !
Thanks for sharing.
C1
Inventor Professional 2015
Vault Professional 2015
satbir.sohal
Message 12 of 16 (211 Views)
Re: DXF
10-11-2012 01:47 AM in reply to: BLHDrafting
Please find the attached file, 'dxf text.ipt'. I tried using derived and thicken option, but I got problems with flat pattern and cuts.
brendan.henderson
Message 13 of 16 (184 Views)
Re: DXF
10-11-2012 08:48 PM in reply to: satbir.sohal
There is a file test.ipt missing from this.
Brendan Henderson
CAD Manager
New Blog | Old Blog | Google+ | Twitter
Inventor 2014 PDS Premium SP2 Update 1, Vault Professional 2014 Subs Release 1 & Update 1
Please use "Accept as Solution" & give "Kudos" if this response helped you.
satbir.sohal
Message 14 of 16 (178 Views)
Re: DXF
10-12-2012 12:15 AM in reply to: BLHDrafting
    Please find the attached file 'test sample.ipt'
Thank you
Valued Mentor
BLHDrafting
Message 15 of 16 (149 Views)
Re: DXF
10-14-2012 02:04 PM in reply to: CAD-One
Gday.
Attached is a zip file of a dataset I created. Have a look at TEST_PART_SOLID.ipt first to see how I created the negative of the shape I wanted (you could use a positive also-depends on your needs). Then look at TEST_PART.ipt to see how I used the DERIVE and then THICKEN tools to create the sheetmetal part. You will need to review the earlier video about derive and thicken. I don't know why you are having trouble. I see that the Cut1 produced dodgy flat pattern results. This is why you should either
  1. Create a solid template (solid could be extruded surface or solid) or
  2. Use Flat Pattern tools.
Best of luck.
Brendan Henderson
Web www.blh.com.au
Twitter @BLHDrafting
Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD, Inv R2013 PDS Premium SP2 Update 3 (Build 200), Vault 2013 Workgroup Update 2 (Build 17.2.9.0)
satbir.sohal
Message 16 of 16 (140 Views)
Re: DXF
10-15-2012 03:42 AM in reply to: BLHDrafting
Thank you Brendan. I have now understood the concept. The geometry is now perpendicular to the sheet. Unfortunately, my CAM software (RADAN), still does not auto tool the produced geometry. The circle and hex do not produce a smooth curve or lines. I might need to ask CAM guys for support.
Thank you for your assistance.
Satbir Sohal
