Inventor General Discussion
satbir.sohal
Message 1 of 16 (489 Views)
DXF
489 Views, 15 Replies
09-20-2012 03:51 AM
    I made a cylinder which is in the attachment. When I flat pattern produce its dxf file, I am not able to get correct geometries. When I zoom into the dxf file, I see that the inner hexagon and circles project irregular shapes and are not concentric.
mrattray
Message 2 of 16 (478 Views)
Re: DXF
09-20-2012 05:25 AM in reply to: satbir.sohal
The flat patern is corect, it's your folded model that's wrong. The way you cut those, well, cuts, is not perpendicular to the face. I suggest you remodel this using a contou flange, then the unfold feature. Make all of your cuts after the unfold feature, then follow it up with a refold. This will cause the edges of the cuts to stay perpendicula to the material and allow the expected flat pattern to be created.
Mike (not Matt) Rattray
satbir.sohal
Message 3 of 16 (473 Views)
Re: DXF
09-20-2012 05:43 AM in reply to: mrattray
Thank you for the reply. I tried that before, but its a lengthy procedure and I had to manually calculate the circumference and pitch and then convert them into rectangular pattern. Is there no alternative option where I can get these done quickly ?
mrattray
Message 4 of 16 (467 Views)
Re: DXF
09-20-2012 05:46 AM in reply to: satbir.sohal
You could just enter a formula intot the rectangular pattern spacing instead of hand calculating it. This way it will be linked to the radius of the cylinder.
*Pro
jletcher
Message 5 of 16 (464 Views)
Re: DXF
09-20-2012 05:52 AM in reply to: satbir.sohal
Can you post a pic of the part I cannot open your part I will not install 2013 again.
James Letcher
2012 Factory Design Suite ( will not load 2013)
What happen to my Inventor :-(
mrattray
Message 6 of 16 (462 Views)
Re: DXF
09-20-2012 05:56 AM in reply to: jletcher
satbir.sohal
Message 7 of 16 (423 Views)
Re: DXF
09-26-2012 03:08 AM in reply to: mrattray
    Can you please make a similar cylinder using contour flange and send me the ipt file. as I am unable to get it.
Active Member
BLHDrafting
Message 8 of 16 (402 Views)
Re: DXF
09-26-2012 09:27 PM in reply to: satbir.sohal
Another option I regularily use is to create a solid of what I want (including the angled cut and the holes/projections) and use the Derive the Thicken method from the sheet metal file. Works great and gets all of the cuts perpendicular with the sheet metal face.
Brendan Henderson
CAD Manager/Owner
BLH Drafting Services
Web www.blh.com.au
Twitter @BLHDrafting
Inventor 2012 PDS Premium SP 2 and Vault 2012 Update 1
Please mark as Accepted As Solution or give Kudos.
CAD-One
Message 9 of 16 (386 Views)
Re: DXF
09-27-2012 04:24 AM in reply to: satbir.sohal
BLHDrafting- Sounds interesting. Can you eloborate " derive the thicken method"
C1
Inventor Professional 2013
Vault Collaboration 2013
Active Member
BLHDrafting
Message 10 of 16 (345 Views)
Re: DXF
09-30-2012 04:46 PM in reply to: satbir.sohal
No problems.
Here is a link to a short video of using the Derive and Thicken method. You basically make a positive (or negative) and import this shape as surfaces, then thicken the surfaces you want. Any protrusions you have in the solid can also be included in this method. Good luck.
http://screencast.com/t/VLBL762Cnck
Brendan Henderson
CAD Manager/Owner
Web www.blh.com.au
