Dxf save fails and gives message "Sketch export failed to initialize translator", even for a simple sheet metal part with no bends. I turned the Translator:DXF and Translator:DWG Add-ins on, but they are listed as unloaded after I attempt a dxf save from the flat pattern of the part. Will not save from a IDW drawing to dxf or dwg either. This started with the 2011 install, which was a clean install. (Did not have the problem in 2010.) Installed service pack 2 and still have the problem. Currently at Build 309. Attaching the part and drawing.
HI,
With regard to the Error you are getting with the translator, I would try the following test.
What operating system are you running?
1. Do not know how to import a dxf, but I tried to open a dxf and it did nothing.
I discovered that dxf and dwg translator add-in actually unload when I close the add-in box.
I was able to open a dxf in Autocad.
2. I am the administrator on this computer and I right clicked and ran as administrator with same results.
I am running IV 2011 sp 2 64 bit on
Windows 7 Professional 64 bit service pack 1
Is it possible to log into the station as local system administrator account. This is standard account with most machines that give the PC local Administrator access. Can you launch Inventor under this account and test creating another DXF file. Your error message maybe related to a permissions issue?
Please let me know.
Roberto
