I use the INV to model large sheet metal weldments and create cut DXF files to be used in Pronest. Within the nesting software i can apply cut, mark, and center mark to different layers of a DXF file. can INV create these different DXF layers. BTW i am the one nesting the files.
Best Regards
Gary
Solved by dlmsdm1. Go to Solution.
I believe you can customise the layer names, line coulour and type (hidden, solid) and maybe even width. But there is a set amount of these export layers and I don't think you can add/subtract them, but maybe turn them off is do-able. See this post for a bit more info. Hope it helps.
This may or may not do what you are wanting.
that looks lke what i am looking for i will give it a try
thanks
Gary
