Inventor Forum
DXF/DWG Export Error
3 REPLIES 3
Raider_71
1343 Views, 3 Replies
Hi just a quick question about DXF exporting a part face to dxf. What could be the reason for me getting an eror "DXF/DWG Export Error" ?
I have uninstalled Inventor and reinstalled Inventor with AV, UAC off and logged in as administrator. Any ideas?
3 REPLIES 3
inchul.lee
in reply to: Raider_71
Hi Raider_007,
Are you experiencing the problem with a simple part?
If the problem is specific to a certain part file, can you uload it for review?
Inchul Lee
Raider_71
in reply to: inchul.lee
Hi Inchul,
No its for all parts. This used to work fine on Inventor 2013 though. Could it be an add-in that did not install properly? I have tried to re-install Inventor but the same issue is still there. What can I try next?
Thanks for your help.
It seems like this is related to DBXBridge.exe If I try to run DBXBridge.exe outside Inventor, I get an error, stating that it cannot run because certain dll's are missing. The dll's are: utx.dll, acdb19.dll, ac1st19.dll, acut.dll, acds.dll Is there a way to register DBXBridge.exe after Inventor is installed?
Autodesk Customer Advisory Groups
