I only have AutoCAD, so I need someone to please convert this DWG file to IGES for me.
Thank you in advance!!!
Solved by rdyson. Go to Solution.
Solved by JDMather. Go to Solution.
AutoCAD will Export *.igs files.
Thank you for the kind reply and for converting the file for me!!!!!!!!!!!!!!!!
I only have AutoCAD 2009 and I could not find the option to export IGS.
I really appreciate your kindness.
I don't have AutoCAD and also need a dwg converted to iges. Can someone please do this for me if I attach the file? I greatly appreciate it.
see attached
Hi guys.
Could someone be kind enough to help me convert a dwg to a igs file?
Thank you in advance.
