Hello
im using IV 2011 RS, the spacing of my suffix is like double spaced it looks like 15 " and i want them to look like 15"
Hi Mike,
from the screen shot it is obvious there are several dimension styles used. Inch mark spacing is caused by overal width of booth lines (main and alternate units). In the cases where the inch mark is not that far and should be (following the rule) I suspect that dimension text has been overwritten manually to include the inch mark.
Please could you check it?
Jozef
(Autodesk)
