Inventor Forum
DWG Scale 1:200
6 REPLIES 6
NoName1990
847 Views, 6 Replies
DWG Scale 1:200
I have drawn a big factory in Inventor. Now I want to get it in to a 2D Drawing (.dwg). But there is no small enough scale. I need a scale of 1:200. How can I do that?
6 REPLIES 6
yannick3
in reply to: NoName1990
Hi
It's simple you just overwrite it; double clic on view and just write your needed scale
Yannick Verreault
INV PRO 2015
MS Office 2007
Win 7 pro, core i7 950, asus P6T WS
nvidia Gforce GTX 295
WD caviar black 500Go
WD caviar black 1To
NoName1990
in reply to: yannick3
oh wow. That was simple... 🙂
Thanks!
g.broomhead
Can you tell me where I can find this drawing view please? I’ve been trying to scale my drawing at 1:200 for hours and everything I’ve tried off the internet isn’t letting me do it
swalton
in reply to: g.broomhead
Silly question, but...
Are you trying to edit the view scale of a drawing (idw or Inventor dwg) file?
You should be able to right click on the view, select edit, and change your view scale.
Steve Walton
Inventor 2023
Vault Professional 2023
g.broomhead
in reply to: swalton
I’m trying to edit a floor plan I made in sketchup that I exported into a dwg and put into CAD. I can see the options to use the scale 1:100 but it doesn’t fit on my A2 paper
johnsonshiue
Hi! The discussion is about Inventor drawing view. If you are using a different product, the discussion may not apply to you. For regular drawing view associative to a model, you can edit the view and change the scale in the dialog. For draft views (sketch-based views), you simply double-click the view -> change the scale.
Please feel free to share an example if you still have trouble figuring it out.
Many thanks!
Software Test Engineer
