When I export my idw to Autocad DWG, there are some lines that on this one part that does not convert well. I have noticed that if I slightly rotate the part, the lines are shown correctly, but at just the right angle, they are not.
They are actually splines in Autocad.
This is not a "2015" thing, but rather something that has been going on for several releases. Just now getting tired of deleting the extra lines. I can probably remodel the part, but should I really have to do that?
Kirk
Solved by johnsonshiue. Go to Solution.
Hi! This is a bug. There is something wrong with the way Inventor convert 2-point spline to DWG. We are actively working on this issue. Before a fix becomes available, please use attached .ini configuration file when exporting to DWG.
Many thanks!
Hi
I have not looked at the .ini file yet, but I assume it is still the same from previous issues.
See the following link wich explains it a little better.
Hope this helps.
