Inventor Forum
DWG is not the same as IDW when exported
2 REPLIES 2
karthur1
256 Views, 2 Replies
When I export my idw to Autocad DWG, there are some lines that on this one part that does not convert well.  I have noticed that if I slightly rotate the part, the lines are shown correctly, but at just the right angle, they are not.
They are actually splines in Autocad.
This is not a "2015" thing, but rather something that has been going on for several releases.  Just now getting tired of deleting the extra lines.  I can probably remodel the part, but should I really have to do that?
Kirk
2 REPLIES 2
johnsonshiue
in reply to: karthur1
Hi! This is a bug. There is something wrong with the way Inventor convert 2-point spline to DWG. We are actively working on this issue. Before a fix becomes available, please use attached .ini configuration file when exporting to DWG.
Many thanks!
Software Test Engineer
rhasell
Hi
I have not looked at the .ini file yet, but I assume it is still the same from previous issues.
See the following link wich explains it a little better.
http://beinginventive.typepad.com/being-inventive/2013/01/lines-in-the-view-are-stretched-after-conv...
Hope this helps.
Reg
2024.2
Please Accept as a solution / Kudos
