Hi Gary,
At this time MDT DWG import will not work on 64-bit machines. I think when
you tried to import, some files were from MDT and some were not. The ones
from MDT will fail and the ones not from MDT will be okay. Can you verify
this?
As you have already figured out, TS1071050 will not solve this problem on
64-bit machines because AOEM viewer is not installed with Inventor on 64-bit
systems.
Kevin Kuo
kevinDOTkuoATautodeskDOTcom
Inventor Developer
wrote in message news:5627093@discussion.autodesk.com...
Well my 64bit PC and Inventor 2008 finally experienced the dwg import crash.
I performed the hotfix as directed under TS1071050 but had problems removing
tyhe AOEMViewer 2008 as it was never installed during the initial
installation process. Installing the component using the hotfix did nothing
but install the component. It did not resolve the problem. Every 32bit PC
I installed the hotfix on was successful. DWGIN worked on those PCs.
The following is my last update on the CER I initiated with Autodesk for
this issue. Sorry, for I hope I'm not the only 64bit PC running XP Pro x64.
on a HP xw8400, 6 gigs RAM, FX3500.
UPDATE
After 2 hours of a clean uninstal of all Autodesk products, past and
present, and then a reinstall of Inventor Suite 2008 (Inventor, Mech
Desktop, ADMS, without Vault); I am again able to import dwgs on my PC.
I have not yet performed the hotfix for the DWGIN issue addressed by
TS1071050 as I do not believe that it will repair this issue on a 64bit PC
running a 64bit OS.
At no time during the installation of Inventor Suite 2008 does it make any
reference to the AOEMViewer 2008 nor does it install this component.
Obviously there is something else causing the DWGIN crash on 64bit machines.
I performed 20 installs of Inventor Suite 2008 on 32bit machines and saw
that the the AOEMViewer component was installed during the initial
TS1071050 seems to have successfully addressed the DWGIN issue on 32bit
installations. It does not address the issue when performed on a 64bit PC.
The only difference I can see is that Inventor 2008 is installed as a 32bit
application (x86) and Mech Desktop 2008 is installed as a 64bit application
on 64bit machines.
While I am again able to import dwgs on this 64bit machine, I feel strongly
that it will fail again at some point in the future. Please do not close
out this CER as nothing has been resolved. Further investigation is called
for and a subsequent fix directed to 64bit PCs should be released.
Please advise.
Gary
