Inventor Forum
dwf save
6 REPLIES 6
230 Views, 6 Replies
dwf save
Is there a way to automatically save a dwf file automatically when the
drawing is saved.
Mark Rodgers
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.543 / Virus Database: 337 - Release Date: 11/21/2003
6 REPLIES 6
We used VBA to do this in MDT, havent looked at reprogramming it in Inventor
yet, but soon!
Paul Houlker
Rimex Supply Ltd
www.rimex.com
hoser_71
I have code that is writen into my idw templates that will automatically save a DWF to a specific folder.
There's a problem with centering the DWF if you use the Save As command to save a
DWF. It has been fixed if you download the DWFwriter and work it into the code.
When I get back to the office next week I'll post it.
Joe Bartels
I have two sets of code for creating a DWF to a
folder.  This one is the current one I use, and it runs off of the
DWFwriter that you can download from the Autodesk webpage.  This was built
using some code I was using to do a SaveAs to create the DWF.  I'll provide
that code in a following post.
Once the DWFwriter is installed open the
DWFwriter 2 Beta driver and under "Advanced
Properties" -> "DWF
Filename" to select "Don't prompt - use source
filename".  Make this choice
and the "Save As" dialog will not appear
any longer.
When DWFwriter 2 Beta is installed, a string value in the
registry is
created with an empty
value:
HKCU\Software\Autodesk\DWFwriter\2\Publish Directory
Change
this value to your desired target directory (with or without a
trailing \)
and your DWF files will land here.
I have also added code that will write text stating
it's a reference document, print the DWF, and then delete the text.  We do
this for our standards.
Here's the code, take it a copy it into your IDW
template.  Everytime you do a save it will create the DWF to a specified
folder:
Option Explicit
Private obDocument As Document
Public WithEvents DocEvents As
DocumentEvents
Public Sub
AutoSave_Copy_by_Event()
    Set DocEvents =
ThisApplication.ActiveDocument.DocumentEvents
End Sub
Public Sub DocEvents_OnSave(ByVal BeforeOrAfter As
EventTimingEnum, ByVal Context As NameValueMap, HandlingCode As
HandlingCodeEnum)
    SaveAsType "dwf"
End Sub
Private Sub SaveAsType(szFileType As
String)
ThisApplication.SilentOperation = True
Set obDocument =
If obDocument.DocumentType <> 12292
Then
        Exit
Sub
    Else
        Dim
szFileName As String
        Dim
szExtension As String
Dim oPrintMgr As DrawingPrintManager
    ' Create a new sketch on the active
sheet.
    Dim oSketch As DrawingSketch
Set oSketch = obDocument.ActiveSheet.Sketches.Add
    'Name the sketch
    'oSketch.Name =
"DWF"
    ' Open the sketch for edit so
the text boxes can be created.
    ' This is only required for
drawing sketches, not part.
oSketch.Edit
    Dim oTG As
TransientGeometry
    Set oTG =
ThisApplication.TransientGeometry
Create text with simple string as input.  Since this doesn't
use
    ' any text overrides, it will default to the active
text style.
    Dim sText As String
    Dim
oTextBox As TextBox
    sText = "<StyleOverride Bold='True'
FontSize='.4'>REFERENCE ONLY<Br/>NOT A RELEASED
DOCUMENT</StyleOverride>"
    Set oTextBox =
oSketch.TextBoxes.AddFitted(oTG.CreatePoint2d(1.5, 3),
sText)
    ' Exit the sketch from the edit
environment.
    oSketch.ExitEdit
 Set oPrintMgr =
ThisApplication.ActiveDocument.PrintManager
    'This is the
name of the DWF printer on my system. Probably should
'Determine this by other means.
'Set the paper size
    Dim oDrawDoc As
DrawingDocument
    Set oDrawDoc =
    Dim
oSheet As Sheet
    Dim oSheetSize As
String
    Set oSheet = oDrawDoc.ActiveSheet
    ' Check to see if a filename is
defined.
    If oSheet.Size = kADrawingSheetSize
Then
        oSheetSize =
kPaperSizeLetter
         '"B
Size"
    ElseIf oSheet.Size = kBDrawingSheetSize
Then
        oSheetSize =
kPaperSize11x17
        '"C
Size"
    ElseIf oSheet.Size = kCDrawingSheetSize
Then
        oSheetSize =
kPaperSizeCustom
          '"D
Size"
    ElseIf oSheet.Size = kDDrawingSheetSize
Then
        oSheetSize =
kPaperSizeCustom
'"Custom Size"
kCustomDrawingSheetSize Then
oSheetSize = kPaperSizeCustom
    End If
    oPrintMgr.Printer = "Autodesk
DWFwriter"
    oPrintMgr.NumberOfCopies =
1
    oPrintMgr.Orientation =
kLandscapeOrientation
    oPrintMgr.ScaleMode =
kPrintBestFitScale
    oPrintMgr.PrintRange =
kPrintAllSheets
    oPrintMgr.PaperSize = oSheetSize
'get the full file name from obDocument
'  szFileName =
obDocument.DisplayName
'Determine the extension of the file
' szExtension = Right(szFileName, 3)
'If the extension is IDW then print a DWF of the file, if not do
nothing
       ' If szExtension = "idw"
Then
szFileName = Left(szFileName, Len(szFileName) - 3) &
szFileType
'szFileName = "I:\Autodesk Inventor\DWF\" &
szFileName
' Call ThisApplication.CommandManager.PostPrivateEvent(kFileNameEvent,
szFileName)
oPrintMgr.SubmitPrint
        'End If
    End
If
oSketch.Delete
ThisApplication.SilentOperation = False
End
Sub
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
This is my old code that will do a SaveAs DWF to a specified folder.
There are problems with this because it will not center the DWF correctly if
there is a view or object outside of the sheet boundary.
You will have to copy it to your IDW template and
change your folder path.
Option Explicit
DocumentEvents
Public Sub
    Set DocEvents =
End Sub
HandlingCodeEnum)
    SaveAsType "dwf"
End Sub
String)
Set obDocument =
Then
        Exit
Sub
    Else
        Dim
        Dim
obDocument
        szFileName =
file
        szExtension =
'If the extension is IDW then save a DWF of the
file, if not do nothing
        If
szExtension = "idw"
Then
szFileType
szFileName
obDocument.SaveAs szFileName, True
End If
    End If
End Sub
Roxana
Hello:
I am looking for a way to quickly save as DWF and wonder if you could give me feedback on this. Perhaps there is now something better than what you've suggested in this thread since I see it's a bit old. I am not a programmer, so I do not really understand what i would have to do with the code you are including here...
Any help would be great.
Thanks.
Roxana
Hello:
Thanks.
