Dave,
Could you provide more info on the problem at hand - what exactly are you experiencing?
- Explain the 'dwf publishing the first sheet of a multi-sheet set' workflow and means you used to determine this.
- Explain the 'appending one sheet to an old drawing set' workflow and how you've tested this.
Martin Gasevski
Software Engineer
MSD-Data Management
Martin Gasevski | Product Manager | Autodesk PLM 360
